Is it possible to generate an orthophoto of a wall (vertical axe)on pix4d survey ?
Hello, I’m new to Pix4Dsurvey, i use it to generate 3D models of bridges and retaing walls. I’d like to know if it’s possible to generate an orthophoto of a vertical surface as on the drawing below.
Thank you for your answers,
Hi @louis.cossart
Thank you for your request, I have replied to you in the PIX4Dmatic thread:
If you want to use PIX4Dsurvey, depending on how you would like to use the orthophoto, you can use the suggestion shared in this post:
Cheers
Hi @louis.cossart ,
I noticed that you asked about the option to generate an orthophoto in PIX4Dsurvey a year ago and I thought it could be useful to share here that that feature is already available in PIX4Dmatic, in case you want to consider using it as part of your workflow.
Diana
Hi, please tell me how this is done in PIX4Dmatic (which command is used for this usecase)?
Thanks!
In order to generate an ortho in PIX4Dmatic, you need to first create a section. Once you are happy with what you are seeing in the bottom panel, you have the option to generate an orthoplane from there.
The entire workflow is explained here Section view - PIX4Dmatic. Let me know if you need any further assistance.
Diana
Thank you very much for the quick reply.
