Irregular Orthomosaic Scaling in Autocad Civil 3D
When importing my orthomosaic to Autocad Civil 3D I am seeing a difference in scaling between a 25% resolution and a 50% resolution. The GCP at the top left of my project looks good at at both resolutions but at the 25% I am missing the bottom right GCP by 0.4’ while in the 50% image I missing it by 0.15’ both lower and slightly to the right. The scales seem to be half or double of each other but again when inserted into CAD they are not lining up with the GCP’s the same. The images are practically the same width and height when brought into CAD I see the 50% at 1627.6814 X 1823.7588 and the 25% at 1627.5676 X 1823.7588. This appears to be the actual scaling of the image coming out of Pix4D. Thanks
Hello!
Thank you for your feedback, we would be interested to investigate this issue further. If possible, could you share those orthomosaic files, please?
If sharing the orthomosaic files is not possible then could you share some screenshots that illustrate this issue, please?
Thank you and kind regards,
Alexey
