@ Michael
To change the arrival point of the grid, you could change the orientation of the grid and try to play with the grid’s size so that one line is added or removed (the end point will go to the left or right corner).
The basic telemetry information is already displayed in the app if you click the battery icon in the Map view of grid mission.
@ Jarrod
May we ask why you need the .csv file?
@ Gv123
The 7-line limitation has been fixed in the latest version 1.2.2.
@ Matthew
Are you still facing the issues you described with our latest version 1.2.2?
It seems like Jarrod and James could solve it by upgrading the drone’s firmware. Did you have the chance to give it a try?
Regarding the camera angle, did you make sure it was set to be vertical in the settings of Pix4Dcapture and DJI GO?
If the drone hovers and does not go to the first waypoint of the grid, it might be because the mission was not successfully uploaded to the drone (see the comments in my first reply above).
@ Power Bee
The circular mission is still at the experimental stage for Bebop 2 since circular missions require more attention because of eventual obstacles in the flight track. Bebop 2 is lighter. We are obviously thinking about implementing something similar for DJI drones but it will take some time.
In the meantime, you can still use the Free Flight Mission of Pix4Dcapture and manually fly the drone around a point of interest (POI).
Images are captured given a space interval (vertical / horizontal distance), meaning the user does not need to trigger the camera shutter but has to manually control the drone. For more information: https://support.pix4d.com/hc/en-us/articles/204261889
@ Piotr
We have not tested the compatibility of Pix4Dcapture with Phantom 3 4K yet. Nevertheless, the Phantom 3 Standard, that is compatible with the iOS version of Pix4Dcapture, has similar connectivity relying on Wi-Fi. This is not available on Android yet, but should be available as soon as SDK3 is used in the Android version, the development team is working on it.
To connect the drone, please select the Phantom 3 Standard in your settings in the iOS version of Pix4Dcapture. Then you need to connect your phone/tablet and the remote control by WiFi. The communication is made through the radio link of the remote controller.
@ James
No, it is not possible to generate the .p4d file without transferring the images from the drone’s SD card to the phone. Both are part of the sync process so far but we have forwarded this suggestion to our developers.
A status bar should be displayed when the mission is synchronized. The synchronization might have failed but the app was probably not responding anymore. Did it happen recently with the latest version and the latest drone’s firmware? If so, would you mind to share with us the app log file?
https://www.dropbox.com/request/OshqYnEG9qLEZHWvLldS
@ Paul
If you are using the latest version 1.2.2 and drone’s firmware, we would be very interested to investigate the case where the sync fails and the app crashes when the drone goes back to the home point. Could you please send the log files?
https://www.dropbox.com/request/LYOwkJ2jJmW9y1VVIPIA
iOS app log files (@ James, Paul)
Look in the LogFile folder next to the Missions folders when you connect your device to your computer using iTunes. Use the Save As… option for the LogFile folder and send us all files it contains called com.pix4d.pix4dmapper.capture date.log.
For more information: https://support.pix4d.com/hc/en-us/articles/203991949
