Hi, I have problem. I made plenty of missions using Ipad. Today I instaled Px4D Capture on my new mobile device base on Android. When I log in the project list is empty.
Please help :)
Regardes
Paul
Please help :)
Regardes
Paul
Hi Pawel,
The missions/projects you planned are saved on the local memory of the device, it is then normal that you will not find them on your Android device.
Also, There is no compatibility in between iOS and Android OS for Pix4Dcapture, the structure of the code being not the same. Then there is currently no possibility to import/export projects from one OS to another.
