Good morning,
I am working on the reconstruction of the facades of a church.
I made flights in manual mode, taking pictures with some overlap.
The result of the initial process is the one shown in the attached photo: part of the facade is curved.
Some photos do not seem to be correctly aligned.
I had thought that it was linked to a wrong correction of image distortion, but even processing the images correcting the distortion the same problem occurs.
Hi Beata,
no, I haven’t tried to use MTPs yet.
I tried to process the images by setting the calibration method to “accurate geolocation and orientation” and the result is much better.
However I don’t know if it’s correct to use this setting.
I attach the Quality Report file.
Hi Beata,
sorry, I explained wrongly.
The quality report of B1_Mattina_00 is related to the standard calibration method.
The result is visible in the photo of the first post.
Below I attach image and quality report of the procedure done with the calibration method "accurate geolocation and orientation”.
You have the Phantom 4 RTK so you can use the Accurate Geolocation and Orientation pipeline.
However, I recommend double-checking the accurancy of your geotags. It could be that it’s a little too optimistic for your dataset. Please reduce it a little and reprocess the project. Afterwards, the Absolute Geolocation Variance in the Quality Report should show better results.
