Best regards.
Recently when processing a large number of images, there is a problem orienting the photos of a Phantom 4 survey, which produces spatially warped orthophotos or unfilled voids.
I would greatly appreciate your help.
Sincerely,
Diego.
Best regards.
Sincerely,
Diego.
Hi @diejodelpi
Can you please post the quality report of your project?
It’s hard to tell what happened here without having more information.
Thank you
Hola,
por favor cargue el informe de calidad para tener màs infromacion sobre el proyecto:
el informe de calidad se encuentra aqui (formato .pdf): …\project_name\1_initial\report\project_name_report.pdf
LELIATERE_FINAL_V3_report.pdf (3.0 MB)
Reporte
Thanks for sending the report.
Could you please give me more information about your license number? Feel free to send me a private message on the community if you prefer to not share the license key here.
The first thing that I noticed is that the project is processed using the rapid options:
This may reduce the quality of the outputs. I suggest you process your project with the 2D Maps template (not the rapid version).
Also, when there are several flights at different flight altitudes, it is recommended to process step 1 for each flight separately, add common manual points and then merge them together. For more information about merging:
Please keep in mind that your computer may not be able to merge all flights together (especially if you process with the full options and not the rapid ones).
I hope it helps.
Looking forward to receiving more information about your license.
Tengo el mismo problema y no es la primera vez que me hace esto, me podrían ayudar es un levantamiento sobre una carretera adjunto captura de pantalla vista desde perfil
El vuelo lo realice con un MAVIC 3 E y su estacion GNSS
EL ARENAL 24 AGO 23_report.pdf (1.2 MB)
