I’m looking for an indices that create a link between soil/moisture/vegetation. Do you have any indices on Pix4dfield that I can use it? or on pix4dmapper? do you have any idea?
Hi Nicolas, I would recommend trying out the different indices and see which one gives the best results for your application. Mostly, all indices reflect the water content/stress and the soil. However, all the vegetation indices normally represent just the stress, you will need to do scouting and take some ground truth data to determine what type of stress it is.
