There is no option to import lines (for example in *.dxf or *.dgn format) and then edit them. This would save time when upgrading the landscape change (e.g. extraction of raw material). Instead of drawing everything from scratch, you can edit lines from a model made e.g. a month earlier.
Greetings.
Agreed. Importing points would be helpful as well… Not GCPs. Just plain old points. It would be great to be able to do this with kml, shp, csv, txt, etc.
