Hello, I lost my drone while using Pix4D.
What steps should I follow?
How can I access the log records?
Hey there,
It is sad to hear that you lost your drone. To access the log record what you can do is try the steps that I have mentioned below:
Hello zydn07,
I’m sorry to hear about your lost drone. If it’s a DJI drone, you can follow the steps outlined in this DJI Support Article to help locate it.
Here are the general steps:
Remember, it’s important to avoid flying in areas where the drone could be lost or hard to recover, like over water or in heavily wooded areas. Always keep your drone within your line of sight and make sure the drone’s GPS signal is strong before taking off.
I hope this helps and you find your drone soon!
Best, Fernando.
Fernando Torres Pix4D Technical Support Team
