hello. I created a 3d grid using pix4dcapture. After that, I saved the information using offline maps → download. However, I don’t know where the file is saved. We would like to post-process this saved file. I use Android.
Hi @ljbliblib,
Welcome to the Pix4D Community .
The offline data is saved internally in the app database and is used for your projects.
The file is located in the app folder, same as where the logs are located, but the file might be encrypted and be used only by the app.
Let me know if this helps you.
Daniele
