How to set coordinate system to allow decimal degrees for GCP's
I’ve discovered that Pix4D is expecting UTM coordinates for GCP’s.
I’d prefer to use decimal degrees - as I’m using for my image geotags.
How do make the right setting to the decimal degree coordinates for GCP’s?
Hi Joe,
To set your GCP coordinate system to WGS84 simply go into the GCP/MTP Manager. Once you open it you will need to edit the coordinate system. Click where the red arrow is pointing. Then you should keep your unit as meter then search for WGS84. This will set it to using decimal degrees.
