I exported the file and the prescription and the shape file correctly.
But, when the route is created, it doesn’t skip the 0 leter per area, I also try using X 0.00 Fill all empty cells. I want to optimize the route so it only goes to the area it has to spray.
1st picture, it’s the operation on pix4farms. 2nd picture the operation with prescription loaded.
How can I optimice the fligh route, so it wont fly the whole field.
This is a limitation by DJI, you need to ask them to add this behavior. We can’t influence the flightplanning of the drone.
So it’s not possible at the moment .
Thanks for the reply
Unfortunately yes. The only option you have is to edit the field boundary of your operations layer and make it exclude no spray zones for mir efficient coverage.
Also I saw an update for Agras drones where you can chain multiple parts fields together, this might be worth looking into.
