Hi guys, I need some help. I have a big amount of data (up to 10,000 photos) collected from an aircraft that I need to process in one project. The problem is that the camera Nikon D810 mounted in the plane is not recognized by the software so I don’t have orientation metadata. If I run the data in Pix4D mapper it works but only up to 2,000 images.
Guys do you know any method to extract and match the aircraft metadata with the camera using the time? how can I get the missing columns (Yaw, Pitch, Roll)?
Eduardo
