I know in Metashape you can export an RGB Orthomosaic from images taken from a multi-spectral camera just by choosing to output the Red, Green and Blue Channels. Can that be done in Pix4D so you don’t have to use images from a normal RGB camera to generate a normal RGB Ortho? On Metashape it’s basically using what is called “False Colors” so you basically say use Red to represent the red channel images, Green to represent the green channel and so forth and it comes out pretty close to an RGB camera output - sometimes you need to adjust the darkness/lightness to make it look better.
Jeff,
My apologies. You are correct that Mapper does not generate an RGB orthomosaic. However Fields does generate the RGB orthomosaic.
Hi
Just wondering if there have been any changes in this regard, or if RGB orthomosaics for multispectral imagery are just not available in Pix4D mapper?
