I am using pix4D for the first time so far it is amazing.
I do have one questions; how to activate the 3D Texture render. After the point cloud has been made, the image is not clear and is very noisy (See attached Image). I tried all the other settings but it just makes it look like minecraft.
I have researched it and it has been stated that there is a 3D texture option that i need to select but i just cant find it in the Pix4DMatic app.
Any help would be much appreciated. Thank you.
Hi @anthony.kolenberg
Thanks for reaching out, glad that the experience so far is good!
The settings you have displayed are for “how” things are displayed. For checking “what” is displayed, you need to go into the “content” panel (should be the top left option, below the Home icon), where you can turn on/off different content in the layers. This is useful only if the content was generated or created manually. If you can’t find a Mesh in the content panel, then it was probably not generated yet, this means you’d need to go to the “Processing” panel, select “Mesh” and hit start to process it.
Hope this helps!
