A while back I read that if you where using a Quadro graphics card it was recommended to load the GeForce drivers or disable the card. Is this still recommended? If so why?
Hello Austin,
Indeed, users with a Quadro GPU have noticed a slow down in the processing time. We believe that the issue is related to the drivers of the GPU. Some users noticed improvements in the processing time when installing the GeForce drivers instead of the Quadro ones.
We believe that it is also worth trying to install the latest Quadro driver to check if there is a fix.
