Hi, i was following the guided tour in order to generate the DSM geo tiff file. since i wanted to open this in Golden software Surfer 16. Such opened imagery height and widths were exaggerated from the original. can you explain me why?
earlier i generated the contour file from pix4D and opened it in surfer 16 for volume calculation. (im aware that the volume calculation can be done in pix4d, but it doesn’t allow to calculate volume of parts of quarry mother rock. )
link to surfer generated image: https://drive.google.com/open?id=1ZYHyh-Uplmj8IAEEA351XGkS5R-2qzie
link to pix4d generated image: https://drive.google.com/open?id=15iaDlDsh6EV9wI9u0JwoVnWF7VLAsuw2
Thank you
It has to be something specific about displaying the GeoTIFF in the Surfer.
I wanted to test it. However, I encountered problems downloading the software. It is not possible on any site I visited.
I submitted the ticket to their Support. Once I get the software, I will test it for you.
Beata
Hi, I must thank you for the effort. But after a long research on both the softwares I found that it is an issue related with the map generation and units per metres exaggeration in surfer software that can be adjusted.
Ah, OK! Thank you for letting us know.
Anyway… probably on the way, we will solve the second problem: broken download on Golden Software webpage
Regards!
