I’ve been using Pix4dMapper with my research group at UC Merced for around 8 or so years and recently got pix4d fields in conjunction with UC Davis to start teaching drone surveying in agriculture. We figured that pix4d fields is a much more intuitive than the older version for multispectral (as well as allowing pan-sharpening for our altum-pt). It processes the data great and very quickly, but we have no way to utilize our fixed GCPs and therefore can not use this for ongoing research projects. Pix4dMapper can’t handle quite as many images as pix4d fields so I’d really like for pix4d fields to support GCPs so we can carry out our research and teach with the latest and greatest. I saw some other messages in the community about GCPs from a few years ago with a mention of an “alignment tool” but I can’t seem to find any info on that.
Would love to get this featured added so we can move forward with our data processing in pix4d fields!
Thank you for your comment. We are glad that you like PIX4Dfields so far for your projects.
Please note that you can process Steps 1 and 3 in PIX4Dmapper to reduce the processing load. (Disabling Step 2).
Unfortunately, we can’t confirm when the alignment tool will be added to PIX4Dfields.
Would Pix4dMapper be able to handle the multispectral imagery from the micasense altum PT? So far I’ve been using Pix4DMapper (the old desktop app), but it’d be nice to use the more modern apps as they are nicer to work with, but lack the multispectral/GCP workflows from what I’ve seen.
You can use Altum PT in PIX4Dmapper, the only downside is that pansharpening is not available.
I am looking to upload .kml or .dsm with points that indicate location of tiling in fields. Is there a way I can do this?
Hi, yes you can import them as annotations.
Import an annotation as Geometry file (GeoJSON, KML, Shapefile)
Annotations are imported into the layer that is currently selected. To import annotations :
- Go to the Annotations tab on the right board.
- Click on Import geometry or images.
- To read the name of each polygon, the column should be called “name” or “title”.
- Choose Geometry files to import as an annotation.
- Click Open.
Tip: To read the name of each polygon, the column should be called “name” or “title”. This will import each polygon with the proper name.
