I use the Emlid RS+ GNSS receiver to measure the coordinates for my GCPs with EPSG:25833 as horizontal coordinate system and EPSG:9274 (Austria height).
It is possible to choose CS EPSG: 25833 as “Known CS” but
what should i select for the “Vertical CS”? EPSG:9274 (Austria height) is nowhere
to find in the dropdown.
The offset will depend on the area of interest and might change over large areas. The offset is the difference between the elevation over the WGS84 Ellipsoid and the elevation according to EPSG:9274.
In fact, once you select the horizontal Coordinate System to be EPSG:25833, the interface will change and will ask for the offset above the GRS 1980 Ellipsoid.
I’m not 100% sure that this is the map you need. Please verify with the local Austrian provider if they can provide a detailed offset calculation according to the region your project is located.
