i am still looking for the best coordinate system settings. The results should be in the ETRS 89/ UTM zone 33 coordinate system (EPSG: 25833) with heights in the official german height coordinate system DHHN2016 (EPSG: 7837). I even get uncertain about the image coordinate system settings (EPSG 4326) for images taken by the DJI Phantom 4 Pro. The main question is, if it is useful/recommended/necessary to use the geoid heights above the ellipsoid? You can have a look at my current settings below.
The coordinate system you should use is the one in which the coordinates has to be expressed. That is the one you have to use as “output coordinate system”. As for the images coordinates, they are usually given in WGS84 (latitude, longitude).
If you want to get the result in ETRS 89/ UTM zone 33 with vertical DHHN2016 (EPSG: 7837), the best is to have GCPs so the project will be tied to this points after the adjustment.
Hi Daniel,
I have GCPs in DHHN2016, Status 170, NHN Height. In my project I set WGS84 UTM Zone 32N with vertical coordinate system EGM96, which was predefined by default. Can I use the same for my GCPs or better change their vertical coordinate system? If I should change it, how can calculate the difference between EGM96 and DHHN2016?
I hope you can help me!
Martin
If my understanding is correct, your GCPs have been measured in WGS84 UTM Zone 32N (EPSG 32632) and Deutsches Haupthöhennetz 2016 (EPSG 7837).
You need to define the correct coordinate system of the GCPs in Pix4D, otherwise they will be wrongly located horizontally and/or vertically. These are the ways to define DHHN2016 heights:
you could provide the offset between the desired datum and the ellipsoid of the selected horizontal coordinate system (WGS84). For this, you should know the shift/offset between the current vertical coordinate system and the target vertical coordinate system (DHHN2016). This shift can be added in the Geoid Height Above XXX Ellipsoid option. It might be difficult to know this shift. Even if you know it, it will only be an approximation as to convert from one system to the other, just one shift is not enough. Therefore, the vertical coordinates will not have everywhere the same accuracy.
You can find more information about when to use the Geoid Above the Ellipsoid Function here: When to use the Geoid Height Above the Ellipsoid Function?
According to this website (see source here), the DHHN2016 elevations don’t seem to be parallel with the ellipsoid elevations (see figure below). However, a local land surveyor might know much more about the mathematical approximation of this vertical reference system, because I am not an expert.
you could select the option Arbitrary for the vertical coordinate system of the outputs and the GCPs, then import GCPs with coordinates in the coordinate system you specified. In this case, the software will respect the GCPs values and will try to fit the model as well as possible to the GCPs. Then, all your outputs will still be in an arbitrary reference system but this system will be based on the system defined by the GCPs (even if the name DHHN2016 is replaced by Arbitrary). Since you have GCPs in DHHN2016, this second option is the most suitable for you. To check the accuracy of this method and see if it is suitable for your purposes, you could possibly try to run a project setting the vertical coordinate system of both the GCPs and the outputs to Arbitrary and using checkpoints. The checkpoints assess the accuracy of the model.
