Hey, is there a way to plan the flight with altitude information in the Pix4d app? Like in this progam? Thank you
Hello Willy,
Are you using the Pix4Dcapture software? If yes, it is possible to adjust the flight height of your mission. This setting will appear on the left side, after you choose the flight mission. All the steps are described in this article: https://support.pix4d.com/hc/en-us/articles/204010419-iOS-Pix4Dcapture-Manual-and-Settings#label6
Teodora
Hello Teodora,
yes, we use the IOS and android Pix4Dcapture software. I know how to adjust the flight height of my mission… But it is only a fixed altitude?
The picture is only for example:
Hello again,
Pix4Dcapture allows flying only at a fixed height, so the altitude will remain the same all along the flight.
Teodora
