We are trying process a large project in Detroit. Initial processing of the drone data is good, but when trying to put in our Plant coordinate system Survey points the site seams to move so far out of position that the screen goes black and cannot be viewed unless you delete the survey points. This happens when you hit the zoom icon. Does all processing need completed in GPC first and the large state plane values first? Is there a way to deliver the data in the client’s plant coordinate system
Hello @timothy.sheriff, as your GCPs are in an arbitrary coordinate system, the software is not able to recommend the images to mark. However, in this case, you can use Basic Editor to mark your GCPs.
