FYI: When using the dialogue box to let the AI know the particulars about the field… The reported dates are one day earlier than the user indicates. Even the day of the flight is reported as x-1… Let me know if I can do some trouble shooting for you.
hi,
It works correctly on our side. Can you share screenshots? Are you using an M3M?
HI Jose,
Yes, I am using an M3M.
I flew on the 9th and copied from the SD card to my computer on the 9th. Here is the folder:
Here are the file properties from a random file in the folder:
Here is a random file from that folder and another way to view it’s metadata:
Here is within Pix4DFields and the Field Insights Generator:
See the date for the flight?
-Mike
Hi Mike,
Can you check the flight date within PIX4Dfields, click on the Orthomosaic, and go to the info tab on the left? It seems we are not reading the date correctly.
Where are you located?
Thank you, Mike. That’s what I was asking for. It seems the Field Insights tool is the one misreading the date.
You can continue using the tool as it is; one day will not affect the model much. We will investigate and solve it.
