Hello! I am using Pix4Dmapper 4.9.0 to process a small dataset of drone images (80 JPEG files taken by L1D-20c), using 3D Maps template. The computer has plenty of RAM (128 GB, while the images take up 1 GB in total).
This same dataset processes OK at GeoNadir.com, and I was able to process other much larger datasets on my computer in Pix4dmapper without any problems.
However, for these data the processing halts at the Initial Processing stage, it cannot compute keypoints:
[2024.03.11 16:50:26][ 13%RAM][ 13%CPU][UI]: Processing Start clicked.
[2024.03.11 16:50:26][ 13%RAM][ 13%CPU][Processing]: Step1Running
[2024.03.11 16:50:27][ 13%RAM][ 13%CPU][Processing]: Substep Keypoint extraction started.
[2024.03.11 16:50:27][ 13%RAM][ 13%CPU][Processing]: Gather image information
[2024.03.11 16:50:27][ 13%RAM][ 13%CPU][Processing]: Generate normalized/thumbnail images
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Processing]: Computing keypoints
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Error]: feature detection bad allocation
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Error]: Computing keypoints failed!
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Error]: >>>Computing keypoints<<< failed with error (failed to run a step!)!
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Processing]: Substep Keypoint extraction finished.
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Processing]: Substep Report generation started.
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Processing]: Substep Report generation finished.
[2024.03.11 16:50:28][ 13%RAM][ 13%CPU][Processing]: ProjectLoaded
[2024.03.11 16:51:35][ 13%RAM][ 4%CPU][UI]: Processing Options clicked.
I attach the processing log with a few unsuccessful attempts…
test_lodge.log (137.8 KB)
What could be the problem?
Thank you,
Olga
