I have downloaded the trial version of Pix4D fields and I am using a MacBook Pro M2, 16GB RAM, macOS Sonoma 14.1.
The first two folders of photos from a drone (DJI Mavic 3M) were processed successfully.
Then the next sets of photos from new flights were stuck at the processing stage (the folder would open and at around 27% of processing it would freeze). One of these times I left the software on and finally got this error:
Failed to stitch images
R0009: An error occurred while stitching the images.
For one of these sets I tried it on the computer of a colleague, who downloaded the trial version, and he got the same problem. Again it would freeze at 27%. That computer was a Dell with Windows 11.
The two sets that would not process were able to work when I used Fast processing (they would only get stuck in Accurate processing). I would appreciate your help to determine why the drone photos would not process. The drone is a new one, with a new SD card that was formatted on the drone before the flight.
Thank you.
