Facade Reflectance Map ?
Is there a way to generate a facade reflectance map, for example drawing a new orthoplane as for orthomosaic?
I’m trying but in Reflectance Map it generate only nadir map and there are no options to generate a new reflectance map with the new orthoplane on the facade…
By the moment is not possible Multispectral ortoplanes
Ok…
Do You know any trick to maybe set the plan of the facade as terrain? In order to process all the project layed down on the surface and obtain a reflectance map?
Yup, changing the reference plane
