I’m doing a test mission for a Survey company using “Carlson Survey” and considering “Carlson Precision 3D Topo” for data processing.
They have marked Ground Control Points which I will place my marker pads on. What I’m wondering is what is the workflow in Pix4D for exporting a file for them to use in Carlson Survey or Carlson Precision 3D Topo? Do I need to do some sort of georeferencing of the GCPs prior to export or do they do that after import?
I just discovered Pix3D. What is the least expensive solution for me to do this considering this is just a one time test and I’m not going to be doing this often anytime soon?
