hello,
i want images of uav with ground control points
thanks,
hello,
thanks,
Hi Ahmed,
If you want to include ground control points (GCPs) to your project, it is required to draw marks (or put targets) on the field, measure them with a highly precise device, and fly the area. After creating the project with the images, the coordinates of the GCPs are imported and the points should be marked on the images where they are located to adjust the model.
For more information about GCPs: https://support.pix4d.com/hc/en-us/articles/202558699
