I am using the parrot sequoia with the Pix4d mapper. I would like to know if there is a way to export the dense point clouds for all the bands. Right now i am only able to export the green point cloud.
By default, the green band is used for generating the point cloud. That is why you are only getting the point cloud from that band. You can generate the point cloud for other bands by changing the Reference Camera using Image Properties Editor and processing step1 and step 2 again. If you want four different bands you have to process your project four times with different reference camera.
I’ll try, thanks
