We use TBC (trimble business centre) to ‘clean up’ the export point clouds from Pix4D, as you’re all well aware Pix4D breaks the point cloud down to multiple clouds (I assume it’s easier for the software to process it) however, when checking in TBC the clouds don’t line up perfectly and are circa 1.5m apart. All alignment of the photos, GCPs etc while processing in Pix4D didn’t throw up and errors, so I don’t believe it’s anything to with the processing of the data, just potentially the export.
I though this could be to do with projections/ co-ordinate systems in TBC, but this wouldn’t cause a 1.5m change in position and importing all the laz files at the same time would by rights make the all datasets relative together thus error error in TBC = dataset all out by the same amount. Which leads me to the export from Pix4D.
That’s my thought process anyway, I’m open to being corrected.
Any assistance/ advice with this would be welcomed as It’s bugging me.
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
▸ The project file (.p4d): …\project_name.p4d
▸ The pointclouds
May I also ask where did you try to import the pointclouds and you noticed this difference? Can you send us a screenshot of the raycloud?
Have in mind that if you want to create one file only that contains the pointcloud you can enable the Merge Tiles into One File option as shown below:
Hello, I had the same issue. Pix4D generated 4 point cloud .las file for me, and when I would import them into TBC they would each have a significant “gap” between them.
Here’s the answer in Reddit that worked: “If your point cloud is already geolocated, when you import it select ‘point cloud from unknown source’ with ‘unknown coordinate system’. TBC will then not shift its position.”
