When I send maps to users, a request that keeps coming up is having the ability to export the ortho map and annotations as a PDF file. Right now, you have to use a screenshot, which is a jpg, then convert to a .pdf, which does not work well. That is because if you have a certain size map and small/large annotations, they quantity will not show up if you are not zoomed in enough.
When using a software like DroneDeploy, we were able to export an annotation report, which numbered each annotation on the map and gave you a separate report at the bottom showing you information about that particular number.
