Errors during reoptimization
I am receiving the following error message when reoptimizing after marking GCPs in the point cloud after step 1 processing:
“[Error]: Error e9031: Cannot reoptimize. Failed to remove some first step directories.”
Anyone else encounter this problem or have suggested solutions?
Hi @tfite, are you still encountering this issue? I have not seen any recent mention of a similar issue. Have you tried on another computer?
I also have this issue “Cannot reoptimize. Failed to remove some first step directories.”
I’m also getting this issue. I tried moving the project to the local C drive as someone mentioned it could be due to onedrive issues. I still get the error. How do we fix this??
Hi guys. UPDATE on the situation.
Pix4d support suggested taking everything off the onedrive server and starting from scratch. This worked. I ended up placing the images and drone data on the C drive, made a new Pix4d job on the C drive and started the processing again. This time everything worked.
