Every time I try to open a project I did yesterday I keep getting this message. Why would I be getting this message on a project I just did on this version?
I am having the same problem - its annoying I do not want to reprocess my older files.
Yes it is VERY annoying when you have to redo a project! I’m wondering if it is a bug in the 2.1.47 version. It didn’t start happening until I downloaded this version. Is this the latest version, or is there another one out that might fix this issue?
Hello Wade,
Could you please give us some more information:
with which version did you process your project?
which version are you currently using?
- are you defining the site calibration?
could you please update Pix4Dmapper and open your project with the latest version 2.1.51?
can you send us the original .p4d file in support@pix4d.com
Best Regards,
Michael, and anybody else having the same issues, this is what I have received back from Pix4D, and it seems to work. Since I have been using version 2.1.51 I have not had it happen. I went back to the projects I created with the 2.1.47 version, and did this to them and it seems to have fixed it.
