When running a Sequoia data set in Pix4Dmapper v 4.4.12, the processing fails on Step 3 with the error in the title of this post. The selected outputs are NDVI map and point-shapefile (not polygon). Any advice is appreciated.
The full error log is:
Processing: Substep Ortho index indices finished.
Processing: Index statistics
Processing: Export range index
[Error]: Contour: failed to read smoothed input!
[Error]: Export range index failed!
[Error]: >>>Export range index<<< failed with error (failed to run a step!)!
