Dear Team PIX4D
Hello.,
I created NDVI project (Step 2 Done) but can’t generated index bellow as ;
" [Error]: Generate index failed!
[Processing]: Substep Ortho index indices finished.
[Processing]: Step2Done
How should I do?
Thank you for Answer.
Which output are you looking to create? Is your project georeferenced (this can be an issue if you try to generate a KML file which requires geolocation). You can go in the Processing options and try to disable some outputs that are not needed (for example in the export section here https://support.pix4d.com/hc/en-us/articles/203891879#label4 )
