Error e9022 / w0920 Invalid Images
I have a dataset from one mission consisting of 2 battery swaps. A large portion of the images (all jpegs-no different from any other mission I’ve flown with our P4P) came back with an error of “invalid images have been detected. Please remove them to process. Error e9022”. I click on learn more and there is nothing and I look on the pix webpage and there is nothing for this error. Any suggestions? There is also a separate error in the log that says
Warning w9020: GDAL Error <4>
these errors come right after adding images, not during one of the processing steps…
Hi Kevin,
Could you please share the following so we can have a further look at the project:
▸ The project file (.p4d): …\project_name.p4d
I have today the same problem also…
warning w9020 GDAL error… the image not recognized as a supported file format
Hi Jacquelin,
Could you please share the files above (log and .p4d)?
What is the format of the images that were imported into the project and which camera was used?
i’ve been getting this same message for quite a few projects recently. We are using a Phantom 4 Pro and are flying the mission at 3-4 different heights.
Any solutions to this?
Was this ever solved? Images below.
Need a solution quick.
Error from log file is as follows (confindential information replaced with “XXXXXXXXXXXXXX”):
quote
[2018.10.09 15:55:57][21%RAM][2%CPU][Warning]: Warning w9020: GDAL Warning <1> XXXXXXXXXXXXXX/FINAL Images Collected/test set/1217866617000000_300.tiff:JPEG compression support is not configured
[2018.10.09 15:55:57][21%RAM][2%CPU][Warning]: Warning w9020: GDAL Error <1> Cannot open TIFF file due to missing codec.
[2018.10.09 15:55:57][21%RAM][2%CPU][Warning]: Unable to open image XXXXXXXXXXXXXX/FINAL Images Collected/test set/1217866617000000_300.tiff
[2018.10.09 15:55:57][21%RAM][2%CPU][Error]: Error e9022: Invalid images have been detected. Please remove them to proceed.
[2018.10.09 15:56:24][21%RAM][9%CPU][UI]: Closing Project.
End Quote
Hi all,
The error you are getting is due to the compression of the images (and it was a bug).
This was not an issue in the previous version but in 4.2.26/.27 some changes were made in the library that is used to read and write TIFF files. Our developers have fixed the issue in the latest version (4.3.27) was released on the 6th of September.
Here you can download the Pix4dmapper 4.3.27.
Cheers!
I downloaded and install the Pix4dmapper 4.3.27.  I am still receiving the error when trying to run a set of images.  I have even removed the files from the folder. The software just fines a new file it doesn’t like.  Can you please help? I have wasted the entire day on this one set of images.
[UI]: Open Project clicked.
[UI]: New Project clicked.
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 1-20181005T145944Z-005/Polygon 1 flight 1/0004SET/002/IMG\_0160\_1.tif: Can not read TIFF directory count
[Warning]: Warning w9020: GDAL Error \<1\> TIFFReadDirectory:Failed to read directory at offset 2463522
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 1-20181005T145944Z-005/Polygon 1 flight 1/0004SET/002/IMG\_0160\_1.tif
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-001/Polygon 1 flight 2/0000SET/000/IMG\_0159\_1.tif: Can not read TIFF directory count
[Warning]: Warning w9020: GDAL Error \<1\> TIFFReadDirectory:Failed to read directory at offset 2463516
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-001/Polygon 1 flight 2/0000SET/000/IMG\_0159\_1.tif
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-001/Polygon 1 flight 2/0000SET/001/IMG\_0169\_2.tif: Can not read TIFF directory count
[Warning]: Warning w9020: GDAL Error \<1\> TIFFReadDirectory:Failed to read directory at offset 2463524
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-001/Polygon 1 flight 2/0000SET/001/IMG\_0169\_2.tif
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-004/Polygon 1 flight 2/0000SET/002/IMG\_0085\_5.tif: Can not read TIFF directory count
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-004/Polygon 1 flight 2/0000SET/002/IMG\_0085\_5.tif
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-005/Polygon 1 flight 2/0000SET/002/IMG\_0013\_1.tif: Can not read TIFF directory count
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-005/Polygon 1 flight 2/0000SET/002/IMG\_0013\_1.tif
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-005/Polygon 1 flight 2/0000SET/004/IMG\_0006\_3.tif: Can not read TIFF directory count
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 2-20181005T152053Z-005/Polygon 1 flight 2/0000SET/004/IMG\_0006\_3.tif
[Warning]: Warning w9020: GDAL Error \<1\> TIFFFetchDirectory:Y:/xxxxxx/Polygon 1 flight 3-20181005T142459Z-001/Polygon 1 flight 3/0000SET/001/IMG\_0064\_2.tif: Can not read TIFF directory count
[Warning]: Warning w9020: GDAL Error \<1\> TIFFReadDirectory:Failed to read directory at offset 2463526
[Warning]: Unable to open image Y:/xxxxxx/Polygon 1 flight 3-20181005T142459Z-001/Polygon 1 flight 3/0000SET/001/IMG\_0064\_2.tif
Hi Billie,
Can you please submit a request to Support and send us a log file and screenshots of the popping up errors that you are receiving (if any)? We will investigate your issue separately and once we will have all the details and solutions to this particular example we will share it here.
Best!
I am trying to do an orthomosaic from images that I capture using an Mica Sense Autumn, and once I upload the images (TIFF format) I get the error e9022, which makes me delete a few images form the file, which lead to the creation of a map that is not fully complete. Would you know how could I fix this issue? I am using the version Pix4Dmapper version 4.6.4
Hi @wtrecdrone ,
Welcome to the community!
It would be very helpful if you can upload the log file and the screenshots of a popping error (if any).
I also suggest downloading the latest PIX4Dmapper version to give it a try. You can find the latest installer link here: PIX4Dmapper technical release notes.
Sincerely,
Rosana (she/her)
LogOutuput Pix4D Error.txt (6.3 KB)
Hello Rosana,
Thank you very much for been so prompt on answering, I uploaded both files that you have asked me. Also I am trying to download the newer version of the app.
Thank you very much!
Elias
Hi Elias,
Thank you for waiting and sharing the log file.
I have found this error could be due to the corrupted image files or the images not reaching the input requirement. In the past, some images exhibited 48-bit integer, or the images were processed by a 3rd-party GIS software, thus having the pyramid in the images already.
Could you please share with us a few images to have a look if you haven’t found a solution already?
For more information: Input files - PIX4Dmapper
I hope this information reaches you well. :pray: If you have found a solution, please also feel free to share it with us. :slight_smile: We would love to learn from our customers as well. :+1:
Sincerely,
Rosana (she/her)
