On version 4.4.12 with large frame format purchased. Trying to import Ultracam Eagle M3 images ~230 images and I get the error right off the jump. Is there an issue with this build?
Hi, Can you please submit a request to Support and send us a log file? We will investigate your issue separately and once we will have all the details and solutions, we will share it here. It should not be due to large format as you have the add-on. Maybe it is due to compression and we had a bug in our previous version but it should not be there in 4.4.12 which you are using. We would need to investigate more.
Hi, i had the same issue with. I attach the .log file. The images includes multi bands info and radiometric correction.
proyecto-integrador.log (2.2 KB)
Thanks for your support
Hello, could you please share 3 images with us?
