Hi All
I am processing three different datasets and I keep getting this error “Error e0104: Network Error - code: 400” while processing all of them. I am doing the processing on a remote computer, to which I connect over SSH in order to start the processing, select the images and so on. I started the processing yesterday afternoon and let it run overnight. When I arrived at the office I saw that the processing of the three datasets had failed with this same error.
I was trying to process the datasets for the second time, the first time I did it they all failed the same way. Between the first and the second processing I processed other datasets of the same kind, by following the same procedure and everything worked perfectly. Could anyone help me?
Cheers Sebastiano
Pix4d Mapper: Pix4Dmapper Pro version 3.0.17
System: Ubuntu 14.04.6 LTS
Camera: MicaSense RedEdge-M
