Thanks for the follow-up. Generally, it is not necessary to use the GCPs as the RTK drone is already very precise. However, it depends on the region and the area you’re modelling. Learn more in Do RTK/PPK drones give you better results than GCPs?
I have to say that I’m a bit confused about what type of data you have. Could you clarify the following:
The images were acquired in WGS 84, ellipsoidal height. Is it correct? If yes, you should choose Geoid Height Above WGS 84 Ellipsoid equal to 0.00
and the following options in the Output Coordinate System.
Do you have the GCPs? If yes in which coordinate system?
We also described step by step instruction on how to handle the input and set the processing options for RTK data. Please have a look at Processing DJI Phantom 4 RTK datasets with Pix4D especially at the FAQ section where we talk about the vertical coordinate system.
thanks for reply. I want my Z coordinate in RGF93 CC44 with geoid RAF18.
if possible with 3 GCP , but with my PHANTOM 4 RTK it’s not necessary GCP. How do with no GCP for good résult ?
There is no direct way to select the RAF18 geoid in Pix4Dmapper and one of the two workarounds need to be applied:
Use GCPs with heights in RAF18. This way the project will be shifted to the position of GCPs and the final results will have the z-values in RAF18.
Set your output coordinate system to arbitrary and your GCP coordinate system to arbitrary , but leave your collected GCP coordinates untouched.
Calculate the offset between GRS80 and RAF18. This can be typically done by tools provided by national surveying societes or governments. Once you get the offset, apply it in the output coordinate system.
As a side note, we recently developed a new software Pix4Dmatic suited mostly for large projects. It also supports different geoid models. See How to work with Geoids in Pix4Dmatic.
Hello there,
Is there better solutions since last year?
Jean, how did you managed to have the best precision in Z without GCPs?
I’m also disappointed about that correction to add manually. Where is the benefits of RTK positionning if the french IGN accept 2 to 3cm of imprecision on Raf18 grid?
Cookie Policy
