Editing polyline vertices
In Survey it is / was possible to walk through the feature, vertex by vertex pressing the Tab-key while inspecting and adjusting them.
Keyboard shortcuts - PIXDsurvey
That essential keyboard shortcut is currently missing in Matic 2.0
@tibor.vari thanks for reporting! We worked hard to make the transition from PIX4Dsurvey to PIX4Dmatic as seamless as possible, but there are always some small details to fix. I hope your experience with PIX4Dmatic has been smooth otherwise. Cheers
@tibor.vari I quickly checked and this is actually implemented in PIX4Dmatic version 2.0: create a geometry, e.g. polyline, polygon, etc., select a vertex, then move on to the next vertex by pressing tab on your keyboard. Could you try again?
You are right, pressing Tab repeatedly let me “walk” vertex by vertex in a polyline.
Great! Let me know if there is any other pain point we can improve for you.
In version 2.0.0 pressing Tab repeatedly do not let me “walk” vertex by vertex in a polyline.
I’m having trouble reproducing this on my end using version 2.0.2.
Is it happening with all polylines, or only specific ones or in specific projects?
If you can share a quick clip of it failing, I’d love to take a closer look!
Kind regards,
Alexey
It seems that in version 2.0.2. it is working again.
Hi @tibor.vari thanks for the update! There is no change in the behavior of this feature that we know of, but let us know if it stops working again.
