during grid mission image capture stops
Dear Sirs,
I have a Phantom3 advanced and I have performed more than one hundred grid missions. During the last two missions the drone didn’t collect all the photos. During the flight I was hearing the characteristic sound of image capture but when I landed the drone many images were missing.
I open the info in the pix4d capture application and I read that the drone had collected 245 photos but in reality it had collected only 165. The rest are missing.
The same problem with the previous one. Instead of 397 photos only 177.
In both cases the last two photos were only 50kb instead of almost 5 MB.
I’m using the last pix4d capture version on android.
Thank you in advance for your help.
Best regards
Konstantinos
Same problem and yet no answer, guess pix4D isn’t very much interested…
@Konstantinos
Our colleague Dimitris forwarded us your app log files to have a look. He will let you know when we have an update.
@Dim
We replied directly under your post.
I experienced the same problem today. I use DJI P4 pro. Flight mission started normally. I inserted the second battery into the drone and started the remaining flight. But the planned some of pictures were not taken after the battery change.
Hi Ayhan,
There are more users asking a similar question and I suggest that we troubleshoot all of them in the following community post: [iOS] Resume mission after battery warning bugs out.
