When i perform a setup , for P4P in DJI Go 4 , say, switch off a sensor, then close it and open Pix4dCapture , does Pix4dCapture receive the setups perfrformed in DJI Go 4 ?
The behavior you are describing has not been reported to us so far. I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
In case the issue is not solved, I would also recommend you to go through our support article on Which image acquisition app can I use with Pix4D’s software?.
Hello Kapil,
Thx. for your reply.
I was asking which parameters that are set in DJI Go 4 App, will be “transferred” to the Pix4dCapture when it is activated, (in the same session: Set a parameter in DJO Go 4 App , as turn Off a sensor, then exit the DJI App and restart Pix4dCapture ).
