Disabling Images from the rayCloud
I used more than one camera taking simultaneous shots and acquired the area with duplicate image file names. I had to create a separate folder for each cameras because of the duplicate file names. Now it is hard to disable exactly the image that I want, because the Image Property Editor does not have a preview and I have multiple images with the same name. If I hover over an image a pop up will appear with the filename path and only then I can distinguish the source (camera) of the image.
It would be really nice to be able to disable images from the rayCloud’s Images Sidebar.
Vusal
Hi Vusal,
There is a solution to your problem :slight_smile:
You can disable an image from the rayCloud. For more information: https://support.pix4d.com/hc/en-us/articles/202558199-Menu-View-rayCloud-Sidebar-Cameras
(see Disable)
Please follow this post: https://community.pix4d.com/t/4412-Selecting-images-to-remove-disable-in-Map-View
