Hoán đổi sang Tiếng Việt
Hi everybody
I need to ask. I have two blocks but the elevation error of two point cloud points is next to each other. How can I put two nearby cloud points to the same value in two adjacent blocks?
Do you have one or two projects?
if you have 1 project with 2 blocks, then you need to add Manual Tie Points: How to add / import and mark manual tie points (MTPs) in therayCloud connecting the 2 blocks: You need to mark the same point on images of the each block
I hope it helps
hi, i have 2 project and mark the same point on images of the each block, but not the same elevation
Could you give us more information in order to better understand the issue:
- How many identical MTPs did you mark in each block? Keep in mind that we recommend is at least 4 MTPs in the intersecting area. Depending on the area, more might be needed.
- Could you attach some screenshots of the elevation difference?
- Did you process the project seperately and used the merging procedure afterward? Or did you process the dataset all at once?
