where do I find dgn file output to share with Microstation?
Hi David,
You can export the objects you draw in the rayCloud (polylines, surfaces) to a dgn file format:
Export Surfaces and Polylines
and the Volumes objects: Export volumes
More information about the Pix4D outputs: Using Pix4Dmapper Output Files with Other Software
I hope it helps ![]()
