We are using a set of 390 geolocated images from DJI Phantom 4Pro covering 3Ha.
There are five GCPs with ID, Northing, Easting, Elevation data in meters (arbitrary coordinate system)
Using GCP Manager/Editor, each of the GCPs were associated with 3, 4 or 5 images.
The problem is this:
When processing with GCPs - the cameras all appear to be looking UPWARDS and the resulting cloud is inverted with +Z down
However:
Processing without GCPs - the resulting cloud is oriented correctly and referenced to WGS84 UTM 10N as expected.
Why would adding arbitrary GCPs cause this inversion?
GCP file:
1002,5440709.383,497996.837,0.552
1003,5440715.502,498052.966,0.311
1004,5440881.230,498054.215,0.312
1005,5441055.452,498032.473,0.958
1006,5441054.981,498127.123,0.390
Northing Values increase towards the North, Easting values increase towards the East
Thanks for any insight!
Donald Gibson
HighCee Aerial Robotics
