I have a project that I want to process by using cloud. The project has about 60+ photos and all of the photos are of one object that has been taken in various angles. To do this, my workflow has been like the following:
Create [New Project]
Add images
On image property, since none of the photos are geolocated (taken with normal non-GPS camera), I changed the coordinate system to arbitrary. However I also tried known cooridnate system as well - just to what happen.
On output coordinate system, I chose arbitrary coordinate system.
On processing options template, I chose 3D maps. However I also tried 3D models as well.
When I hit [upload project files], then the upload doesnt go beyond 0% (when I chose 3D map for processing template] or 1% (when I chose 3D model), and if I leave the computer on uploading progress bar, soon the computer becomes extremly slow and then freezes.
Since I have sucessfully upload a project to cloud with geolocated drone images before, I am suspecting cloud processing does not work with non-geolocated images. Is my understanding on this matter correct? If so, is there any way to process non-geolocated images on pix4d?
Thank you for your answer.
