I was just wondering how great it would be to be able to copy/add one dataset to multiple sites.
Because the project I am working on is quite big, it is spilted in few different parts.
Sometimes it is needed to make a drone flight which covers more then one of these parts.
Sure it could be solved with multiple uploading of the project from Pix4Dmapper, but maybe it could be possibility to make it easier and less time consuming.
Or maybe it could be also an option in Mapper to cut the project in different parts after calculation and upload them separately…
Thx
Ludvik
Hi Ludvik,
Could you elaborate further on your request? Which part would you need to automatize the most or what is the part that is taking you a lot of time: splitting the project, uploading, assigning the project to a site…?
Are you processing in Pix4Dmapper or on Pix4Dcloud? It’s possible to split a geolocated dataset directly in Pix4Dmapper and later upload the single sub-projects to Pix4Dcloud. I am not sure this entirely covers your request.
Cheers
Hello Alice,
Thank you for the reply.
I am processing first step in mapper and the rest on cloud.
I am not sure what exactly you are asking me, sorry. But I think you hit the nail with the description of splitting the project into sub-projects.
But as I said above, I do not have this opportunity since we process on cloud, right?
Splitting the dataset means subdividing the imagery into groups that will then be processed separately. For these different projects, it’s possible to process the first step in Pix4Dmapper and the rest on Pix4Dcloud.
It’s not possible to separate the output results in Pix4Dmapper or Pix4Dcloud.
