Hi Pix4D team,
Is there any tool available in Pix4D to generate a polygon showing an extent of a point cloud other than drawing it manually? This could be for a point cloud generated using LiDAR or photogrammetry.
Hi Pix4D team,
Hello Henok,
I am not sure if I understand well.
Do you want to be able to automatically draw the point cloud extent?
If that is the case, there is no tool available in Pix4D for now.
Thank you for your suggestion.
Hi Daniel, Yes that was what I wanted. Thanks for the reply.
