CPU-Usage is low in Step 1
i have a question to CPU-Usage in the Step 1 (calibration):
In some substeps the CPU ist running between 3 and 75 % with all cores, always going up and down. In some substeps only with 3 % and 1 or 2 cores! But never with 100 % and a constant power. The CPU ist a Threadripper 3960 with 24 cores.
The GPU (Quadro P2200) ist running with max. 12 %, i have already changed the nvidia setting to 3D GAME DEV in the settings and get the newest driver.
I have a fast SSD and 128 GB RAM - so were could be the bottleneck?
And does somebody has informations about the substeps of Step 1? I didn’t get the logic of “optimizing”, “optimizing with geoinformation” and so on.
I don’t understand why Pix4D is not running on 100% CPU-Power.
Any suggestions? Thanks!
Ok, we got the “problem” solved.
When deactivating the GPU in the Pix4D-settings the processors are running in full speed. So the Quadro-GPU is the bottleneck in our system.
Maybe this Information is useful for somebody…
Thank you for your feedback.
It is expected that the CPU is not running at 100% (in step 1) if a GPU is selected.
Are you also experiencing differences in processing time?
In many cases, the GPU can help speed up the processing, but all systems are different.
I hope other users could find this information helpful. :white_check_mark:
More information about PIX4Dmapper and GPU can be found here:
Cheers
